JD4500 Intake Heater Problems
   / JD4500 Intake Heater Problems #1
MMH
Murrysville, PA
JD 4500
I have a 4500 that I have some starting problems on. Can someone outline the procedure to check out the intake heater system?
   / JD4500 Intake Heater Problems #2
The easiest way is to take the intake hose off at the engine, turn on the key and feel for heat.
On Edit: If it has the setup as my old 4310, you have to push in on the key in the on position to make it work.
Thank you. Checked it out & it is fine. Not only hot, but red hot...
   / JD4500 Intake Heater Problems #4
That grid does get very hot.
1240 (A50490)
1240 (A50490)
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
19008 (A48082)
19008 (A48082)
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
