3-Point Hitch JD450 tiller compatible with a JD2520 Series Tractor
   / JD450 tiller compatible with a JD2520 Series Tractor #1
North of 60
Hey there - Need some advice & knowledge....I am looking for a 3 pt tiller and came across one (JD450) however it's a Catagory 0 3 pt. hitch & I was wondering whether this is compatible with my JD 2520 which has a Catagory 1 3 pt. hitch system?
Any help on this appreciated greatly. thks.
   / JD450 tiller compatible with a JD2520 Series Tractor #2
What is the maximum pto Hp considered for the 450? Category 0 - your 2520 might have more "twist" back there than the 450 would stand up to for any length of use.
That said, I know that most tractor supply places or dealers will have adaptor bushings and pins that you can use to replace your CAT I pins.
AKfish
   / JD450 tiller compatible with a JD2520 Series Tractor #4
I think it will work just fine after you adapt it to the CAT1 3PH. I believe it's the same as the 550 Tiller which is already setup for CAT1.
I found this: http://www.deere.com/en_US/govsales/purchaseguide/PDFs/100_101.pdf
The 450 is not the same as a 550 tiller... not in the same league at all. The 550 is about 200 lbs heavier.
'Course it may still be OK - there's only a 3-4hp difference at the pto between the 2520 and the 455 diesel. So, you could most likely retrofit the pins up to CAT I and "turn that dirt"!
AKfish
Much appreciated thks.
   / JD450 tiller compatible with a JD2520 Series Tractor #6
AKfish
I stand corrected:thumbsup:
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2013 Chevrolet Tahoe SUV (A55853)
2013 Chevrolet...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2017 Ford Explorer SUV (A56859)
