3-Point Hitch JD450 tiller compatible with a JD2520 Series Tractor
   / JD450 tiller compatible with a JD2520 Series Tractor #1
North of 60
Hey there - Need some advice & knowledge....I am looking for a 3 pt tiller and came across one (JD450) however it's a Catagory 0 3 pt. hitch & I was wondering whether this is compatible with my JD 2520 which has a Catagory 1 3 pt. hitch system?
Any help on this appreciated greatly. thks.
   / JD450 tiller compatible with a JD2520 Series Tractor #2
What is the maximum pto Hp considered for the 450? Category 0 - your 2520 might have more "twist" back there than the 450 would stand up to for any length of use.
That said, I know that most tractor supply places or dealers will have adaptor bushings and pins that you can use to replace your CAT I pins.
AKfish
   / JD450 tiller compatible with a JD2520 Series Tractor #4
I think it will work just fine after you adapt it to the CAT1 3PH. I believe it's the same as the 550 Tiller which is already setup for CAT1.
I found this: http://www.deere.com/en_US/govsales/purchaseguide/PDFs/100_101.pdf
The 450 is not the same as a 550 tiller... not in the same league at all. The 550 is about 200 lbs heavier.
'Course it may still be OK - there's only a 3-4hp difference at the pto between the 2520 and the 455 diesel. So, you could most likely retrofit the pins up to CAT I and "turn that dirt"!
AKfish
Much appreciated thks.
   / JD450 tiller compatible with a JD2520 Series Tractor #6
AKfish
I stand corrected:thumbsup:
19010 (A55851)
19010 (A55851)
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
