JD445 PTO Switch Problem
/ JD445 PTO Switch Problem #1
dfeck
Western, NY
Kubota B3200
I have a JD445 with a 47" snowblower that will not engage when the PTO switch is engaged. The PTO switch appears to be okay as I used a volt meter to ring out the connections. Is there a relay somewhere inline with the switch that may be bad? Does anyone have an electrical diagram of the PTO harness?
BTW - The light on the dash also does not light up.
Thanks in advance!
/ JD445 PTO Switch Problem #2
Dfeck,
How old is your tractor?
Do you have the RIO (reverse implement operation) system in your tractor?
If so, it could have something to do with that switch, or an adjustment for it...
If you don't have that system, I guess it could be a relay...
hoping others may ring in, I am experiencing a similar problem
with my 93 that has 750 hrs on it..
good luck,
/forums/images/graemlins/cool.gif
I believe the tractor is a 98! This is not mine but was given to me by my Father for the winter to snowplow my driveway. I did get the PTO working but I still believe there's an issue. It appears I need to drive forward at a slow speed before the PTO will engage. This makes no sense to me! It might be an adjustment issue with the RIO. I believe it should engage with me sitting on it when it's at a full stop. It will only engage when the tractor is moving. How does one adjust the RIO?
/ JD445 PTO Switch Problem #4
You are probably right... it's in the RIO switch adjustment.
See if you can slide the switch away from the bracket that engages it, I don't have that system on my tractor, but
it certainly sounds like that's all your problem is..
/ JD445 PTO Switch Problem #5
Go to Yahoo Groups and look up John deere Garden tractors and there is a John Deere Mech. named Stan and I'm sure he will give you the answer!
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
White Metal Roof Vents (A64194)
White Metal Roof...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A61572)
2025 Hydraulic...
