jd4310
   / jd4310 #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
Thank you to all who responded to my question regarding my new 4310 and the engine lugging problem. I had a chance to take it to the dealer, and he indicated a "brake adjustment" had to be made. With internal wet disks I am not sure exactly what he meant, but my lugging problem is nearly resolved. My tractor still requires judicious use of pedal when climbing steep grades, but has a good bit more torque on my initial post-adjustment use. I, like most posters, am interested to see the new mid chassis tractors, but after having looked through a brochure from the John Deere Florida Product Meeting, it seems many of the changes are cosmetic. The engine numbers seem similar, as do the hydraulic numbers. I estimate 6-12 months for JD to refine the new models and correct any underlying problems, then perhaps I will look. Until then, I am quite pleased with my (improved) 4310.
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2013 Trailer (A60460)
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
