JD4310 with 59" Snowblower, rake, 5ft mower
   / JD4310 with 59" Snowblower, rake, 5ft mower #1
evilgriff
Bought this today, going to fix it up over the summer at my cousin's house. Was sitting for a long time, jumped it and it cranks but would not start. Any common problem with these? Once I get it started I guess I will know more. Have only had a Kubota BX, but never a Deere of this size.
Anyone know how to release the transmission, I believe it is Hydrostatic and all other tractors I had there was a neutral or a valve release. I have to put it on a flatbed.
   / JD4310 with 59" Snowblower, rake, 5ft mower #2
Does it have a hi lo range shifter? If so there should be a neutral position also.
Just found a manual. Looks like there are some steps, one being a range lever like you mentioned. Picking it up tomorrow, guess I'll play it by ear. Thanks.
   / JD4310 with 59" Snowblower, rake, 5ft mower #4
when you turn the key you should hear a click - fuel shut off valve could be stuck or bad there is also a thermistor that goes bad - look in deere section you will find a thread
Will check that thread. Thank you so much. Going to flat bed it out tomorrow, then try to get it going when I have time to visit him. Want to teach my daughter about how to run equipment, good to have girls learning this as well.
   / JD4310 with 59" Snowblower, rake, 5ft mower #6
It looks like there was a Curtis cab on the tractor at one point in time.
The cab is there, found the doors and other parts in a heap in the yard. They look rough, but did not have time to assess all of the pieces yet. Tractor needs some TLC, but the price seemed right so I bought it as a project to work on with my cousin, his kids, and my daughter. If the arrangement works for all of us, fine, if not, might just sell it. Personally I don't have a place of my own to keep it. Used to have my own place and enjoyed my Kubota, this is a great hobby and good skills to learn to operate, repair and maintain these machines.
   / JD4310 with 59" Snowblower, rake, 5ft mower #8
Looks like a great project. I don’t understand how someone could just park this and leave it sit. I’m sure there was a reason, but why didn’t they try to fix this machine that was probably close to $25k as equipped, new?! I can’t stand to have something sitting around that doesn’t work. But, that’s just me at this point in my life.
   / JD4310 with 59" Snowblower, rake, 5ft mower #9
I feel the same way. I'd love to find something like this as a second tractor.
   / JD4310 with 59" Snowblower, rake, 5ft mower #10
Just put the range selector in neutral.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
HUSQVARNA RIDING...
2016 GENIE S65 TELESCOPIC BOOM LIFT (A60429)
2016 GENIE S65...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
