JD3520 will not start
/ JD3520 will not start #21
There are components (control module/relay combo) in many modern cars (and tractors) that need about 9 volts to energize, or you'll see exactly what you described.
from post #1
what's happening is that when the key is turned on there's a clicking noise in the guage cluster and the idiot lights all flash off and on. that's all it does. the starter doesn't try to crank. nothing. just the noise in the dash and the idiot lights flash off and on. no error codes. nothing. fuses are all ok.
add this hint from post #5
the rpm, mph, fuel guage would peg out to their max
The first thing, when I get a call with those symptoms, is make sure I have the proper battery in stock for the vehicle in question.;) (edit: a bad alternator will drain a battery and cause the same symptoms)
Glad you're back up and working Ken.:cool:
/ JD3520 will not start #22
Tug, no reason to appologize! This site has a wealth of great information (often from you), and I enjoy reading it a great deal. I too am from the "old school" but don't have the extensive experience/knowledge to contribute very often, but I do try when I can.
My 3520 is also a 2006 model. I traded for it "used" in early 2007. The battery failed in the fall of 07 and the symptoms really confused me. My battery was showing 12 volts and the lights appeared to work normally. Two "automatic" type battery chargers both refused to charge it and indicated it was already fully charged. After checking everything else I could think of, In despiration I check the voltage while holding the key in the start position and noted that itwas dropping to about 10 volts. I pulled the battery and had it load tested, finding that it indeed had one dead cell.
Take care!
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
PORTA POTTY (A68842)
2007 Freightliner M2 112 Dump Truck (A66736)
2007 Freightliner...
