JD3520 3PH lever needs tightening
   / JD3520 3PH lever needs tightening #1
tuolumne
Danby Vermont (soon)
My three point implements will often slowly drift downwards, especially if the tractor is on bumpy terrain. Is there a way to snug up the lever to prevent this? It seems to have gotten worse lately.
   / JD3520 3PH lever needs tightening #2
Most have a lock nut of some type.
That said, I don't use my lock nut. Use a short bungie instead.
   / JD3520 3PH lever needs tightening #3
From the White Album.
Thanks. Now for the challenge of access to those nuts!
   / JD3520 3PH lever needs tightening #5
My 3520 does the same thing but it falls fast. It just happened all of a sudden one day so something must have broken. I have to bungee it now when I am traveling or the implement will hit the ground hard. It's aggravating but something that I can work around.
   / JD3520 3PH lever needs tightening #6
For some reason I was thinking you were talking about the top link of your 3pt was unscrewing. Sorry, my bad.
   / JD3520 3PH lever needs tightening #7
Do you see from the attachment above how to adjust the lever, and can give that a try?
Bush Hog 2820 (A50120)
43006 (A51691)
43006 (A51691)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
