JD3520 3PH lever needs tightening
   / JD3520 3PH lever needs tightening #1
tuolumne
Danby Vermont (soon)
My three point implements will often slowly drift downwards, especially if the tractor is on bumpy terrain. Is there a way to snug up the lever to prevent this? It seems to have gotten worse lately.
   / JD3520 3PH lever needs tightening #2
Most have a lock nut of some type.
That said, I don't use my lock nut. Use a short bungie instead.
   / JD3520 3PH lever needs tightening #3
From the White Album.
Thanks. Now for the challenge of access to those nuts!
   / JD3520 3PH lever needs tightening #5
My 3520 does the same thing but it falls fast. It just happened all of a sudden one day so something must have broken. I have to bungee it now when I am traveling or the implement will hit the ground hard. It's aggravating but something that I can work around.
   / JD3520 3PH lever needs tightening #6
For some reason I was thinking you were talking about the top link of your 3pt was unscrewing. Sorry, my bad.
   / JD3520 3PH lever needs tightening #7
Do you see from the attachment above how to adjust the lever, and can give that a try?
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
