JD3520 3PH lever needs tightening
   / JD3520 3PH lever needs tightening #1
tuolumne
Danby Vermont (soon)
My three point implements will often slowly drift downwards, especially if the tractor is on bumpy terrain. Is there a way to snug up the lever to prevent this? It seems to have gotten worse lately.
   / JD3520 3PH lever needs tightening #2
Most have a lock nut of some type.
That said, I don't use my lock nut. Use a short bungie instead.
   / JD3520 3PH lever needs tightening #3
From the White Album.
Thanks. Now for the challenge of access to those nuts!
   / JD3520 3PH lever needs tightening #5
My 3520 does the same thing but it falls fast. It just happened all of a sudden one day so something must have broken. I have to bungee it now when I am traveling or the implement will hit the ground hard. It's aggravating but something that I can work around.
   / JD3520 3PH lever needs tightening #6
For some reason I was thinking you were talking about the top link of your 3pt was unscrewing. Sorry, my bad.
   / JD3520 3PH lever needs tightening #7
Do you see from the attachment above how to adjust the lever, and can give that a try?
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
