JD31b post hole digger
/ JD31b post hole digger #1
joed3320
Hinesburg,VT
Johndeere
I have a 3320 and a chance at a JD31b digger is this a heavy or light duty digger,will it do the work in clay soil with few rocks(9")
/ JD31b post hole digger #2
I thought that I had a JD 31a - but after looking at the stamped plate on the gear box - it's a 31b.
I don't think it's a heavy duty PHD, but it's not a light duty one, either. At least, it's alot beefier than the ones I saw recently at TSC....
Hard packed clay is a bugger to work with - plowing, discing, tilling - just about anything you try to do with it; it's a challange!
Digging post holes would likely be a situation of timing.... not too wet and not too dry. I'd guess that the 31B would probably do as well as alot of other diggers - better than some and not as good as say; a power down, commercial unit.
If the price is right and the gear-box is tight (the only thing that you can really "kill") it's done good work for me the past 7 years.
AKfish
/ JD31b post hole digger #3
I have a 31B with 6", 12" and 14" augers, seems to turn these easily. I am going to give it a good work out behind my 4520 very soon to drill holes for my line posts.
I have had this phd for a number of years and it works well IMHO. I did buy a planetary PA30 for my backhoe for tough spots, it will go where the 31B won't dare to go.:D
Thanks guys I will continue with my purchase
/ JD31b post hole digger #5
I would add that Darin Divinnia has a down pressure kit on his phd and claims it works well. Might want to check that out too.
Rogator RG1100 (A63688)
Rogator RG1100...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2018 Ford Focus (A61574)
2018 Ford Focus...
