JD1020 flooding part II
/ JD1020 flooding part II #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
hopefully the problem is solved..apparently, the gas was going by the threads of the seat and thru a very small groove in the casting that was under the gasket of the seat; i put a neoprene O-ring under the gasket this wk-end; and it solved the problem...i "assume" the gasket material was to hard to go into the small groove, but the O-ring worked like a champ..
heehaw
sorry to raise this one again; but the flooding problem is not solved; it happened again Jan 1; gas running out of the carb, after shut-off; i have installed 3 needle valves and seats; from a local auto parts store that also sells tractor parts; my next attempt is a JD needle and seat...
or a used carb if i can locate one.
heehaw
/ JD1020 flooding part II #3
HeeHaw, check for a non-floating float. That could also cause flooding. Good luck.
Rob
did that; right now i have the screws on the top of the carb loose, so i can see the float, and know it has the needle valve pushed into the seat; i am going to hook an electric fuel pump to it tomorrow and see if gas goes into the bowl.
heehaw
/ JD1020 flooding part II #5
heehaw,
I know very little about a JD1020 carb,but I was wonder does it have a diaphragm which might be worn or a hole in it which is letting your fuel pass by.
Thomas..NH /w3tcompact/icons/wink.gif
/ JD1020 flooding part II #6
heehaw, is there rust/dirt in the tank intermittantly interfering with the needle seating?. A slug of lacquer thinner some times will cut the varnish residue from old gasoline that has dried up.
RCH
i've had the carb cleaned; and have a fuel filter on the line from the tank to the fuel pump; but that is an area i haven't thought about; i will add a new filter from the pump to the carb. i really appreciate your suggestions..
the carb is an up-draft type; no moving parts except the float, and it is brass, and floats fine; the carb is mounted at @ the same height as the middle of the gas tank; if the tank is full; with the engine shut off, the carb will overflow (takes a day or so); once the level of the gas is lower than the carb, it stops. i went to the local JD dealer yesterday and talked to the shop foreman; told him what it was doing; his answer was "it needs a kit in it": so i asked what the kit had in it that would stop the gas flow other than a needle valve and seat; "it needs a kit in it" was the reply again, oh well..the kit is $42; the needle valve and seat is $22 from JD; from the auto parts store its @ $6.50, and they "appear" the same except for cosmetics on the seat.
after i hook up the electric fuel pump, i have it rigged so i can put pressure on the needle valve with a thin screwdriver, i will be able to get a better idea of where the fuel is coming in. if it's going past the needle valve, i'll put a JD set in it.
heehaw
/ JD1020 flooding part II #8
I used to have a 5-gallon pail of carb/parts cleaner with a basket I bought at a NAPA store. Sure did a good job of cleaning things up. Fixed up a few carbs too.
If it's an intermittent problem, I'd suspect dirt or residue. However, checking the float level is one thing I haven't heard mentioned--float levels are often checked with a twist drill and adjusted by bending the float arms. A manual should provide specs.
ok; i hooked up the electric fuel pump to the carb, and could still see gas flowing into the bowl, even after i put pressure on the needle valve with a thin screwdriver; so i took the bowl off, and turned the top part of the carb upside down, which put the weight of the float on the needle valve; turned on the electric fuel pump and a very slight amount of gas was coming up around the threads of the seat. the seat has a hard phonelic like washer under the lip, and gas was coming out between the two; i unscrewed the seat, again, and this time put @4 or 5 wraps of teflon tape around the threads( sure hope it works in gasoline), and put the seat back in; no leaks this time, used the tractor for @ an hour with no problems, i sure have my fingers crossed.. when i had put the neoprene O-ring under the lip of the seat before, it would probably have worked, except i put the hard phonelic type washer on too, and it "appears" the gas comes out between that hard washer and the seat..
heehaw
2015 TROXELL 130BBL VACUUM TRAILER (A65643)
2015 TROXELL...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
