JD x748 disengage transmission
/ JD x748 disengage transmission #1
Overseh
JD 455 / JD x748
Hello,
It seems I'm unable to disengage the transmission on my x748.
I'm moving a rod, with a disc at the end, up or down on the right side (rear), with a but nothing happens. No click. Nothing and still hard to push
Is it me or else ?
/ JD x748 disengage transmission #2
Welcome to TBN
Going to need more info on what is happening. Am sure we can then help..
A few pics with some pointers to what is not working too.
What I hope to found is the exact location of the disengage rod and how to move it.
/ JD x748 disengage transmission #4
Not sure what you are "disengaging".
This video shows an x748 and only seeing a forward and reverse pedal.
What is up with yours?
/ JD x748 disengage transmission #6
Wondering if the OP is trying to get the transaxle in neutral to allow pushing/pulling the X748?
If like older hydro tranny''s, there are check valves in the top of the tranny that the rod along the side will press down.
Can get at them by removing the seat and the fender deck.
Again, a pic of what is or isn't working would help.
/ JD x748 disengage transmission #7
I have no problem moving my X750 by pulling the rod out now. At first it would pull out very easy until it seems to hit a stop. This is the internal valve I believe. Mine would not move either when effort was applied. I then pulled the rod more firmly pass this "stop" and the rod moved farther, and the tractor could be rolled with little effort. I hope this helps you.
/ JD x748 disengage transmission #8
Manual shows Free-Wheeling Lever inboard of right rear tire
1..stop engine
2..pull free-wheeling control lever fully up to open the valve
3..unlock parking brake
4..push machine
UNUSED IRANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED IRANCH MINI...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
(1) CABRIO WASHING MACHINE (1) HE WASHING MACHINE (A60432)
(1) CABRIO WASHING...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
