JD X485 Fuel thirsty
/ JD X485 Fuel thirsty #1
inseeme
Stoneville, NC
Kubota M7040
I have about 72 hours on my x485 and I guess my only really complaint is houw much gas it drinks, do others think that it is fuel thirsty?
/ JD X485 Fuel thirsty #2
Mine is. /forums/images/graemlins/tongue.gif
/ JD X485 Fuel thirsty #3
At least your's is fuel injected. The carbureted ones really suck the fuel down.
John M
/ JD X485 Fuel thirsty #4
My X-575 is a gas hog, wish it was diesel. I will be selling it soon so that worry will be history..
/ JD X485 Fuel thirsty #5
What is "thirsty"?
For my X595 (diesel) I can run at WOT for one hour and use ~ .7gal.
I have only one complaint about the X595. That darn fuel level indicator is either 3/4 to full or about to run empty. There seems to be no middle (1/2 1/4 etc.)! /forums/images/graemlins/frown.gif
/ JD X485 Fuel thirsty #6
The X495 (Diesel) is the way to go. I replaced my 318 with it and I am very happy! I belive this mower will out last a couple mower decks and me.
/forums/images/graemlins/grin.gif
/ JD X485 Fuel thirsty #7
Yup, have 25 hours on an X585. It drinks a lot of gas. particullay with when PTO is engaged.
Should have bought a 2210, should have bought a 2210,should have bought a 2210,should have bought a 2210,..........
/ JD X485 Fuel thirsty #8
Guess I'm one of the few that isn't worried about the amount of fuel consumed by my X585. I have a 120' driveway to plow and 1.5 acres to mow. Before you tell me that I could have bought a smaller unit, please understand that I feel Tim Taylor is conservative.
/ JD X485 Fuel thirsty #9
My LX280 gas mower seems to be thirsty when compared to the things I've done with the bigger and heavier 4100 which is a diesel. Sure makes me think I should have gone with a diesel mower /forums/images/graemlins/smile.gif
/ JD X485 Fuel thirsty #10
Ditto. /forums/images/graemlins/grin.gif
I had a GX335 with the 20-hp Kawasaki before I got the X, and I was amazed (and alarmed /forums/images/graemlins/shocked.gif) at the amount of fuel it took. Now I can fill up with diesel and mow my 5 acres, then do odd-jobs (hauling with trailer, harrowing) for a week or so before I need to refill.
/ JD X485 Fuel thirsty #11
My 4010 uses 0.45 gallons/hr. Based on extensive data on automobiles, a carbureted model would use 50% more. A fuel-injected model would use only about 25% more. Otherwise, prorate on hp if nearly same weight or weight and hp if different weight. The 4010 is 18.5 hp and about 2600# with FEL and LX4.
If you're ever comparing automobiles/trucks, the above factors work, but mostly just on weight.
Ralph
/ JD X485 Fuel thirsty #12
</font><font color="blue" class="small">( I have only one complaint about the X595. That darn fuel level indicator is either 3/4 to full or about to run empty. There seems to be no middle )</font> Hey awlchu - Had kind'a the same problem with mine - except it read FULL all the time!! The dealer replaced the gauge package, but it still does the same thing!! Since it sips diesel at such a leisurely pace, I just make sure I fill up each time I mow, and, no prob's. That diesel's definitely the way to go.
Oops!! That has nothing to do with the original post. /forums/images/graemlins/blush.gif
/ JD X485 Fuel thirsty #13
I upgraded from a 335 20HP gas to a 355D 18HP. The rated fuel consumtion is half on the 'lil diesel. I'm sure the comparable X series engines are the same.
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2013 Crane Carrier Co. Low Entry T/A 25Yd Rear Loader Garbage Truck (A61573)
2013 Crane Carrier...
2015 Toyota Tacoma Ext. Cab Pickup Truck (A61573)
2015 Toyota Tacoma...
