JD X485 Fuel thirsty
/ JD X485 Fuel thirsty #1
inseeme
Stoneville, NC
Kubota M7040
I have about 72 hours on my x485 and I guess my only really complaint is houw much gas it drinks, do others think that it is fuel thirsty?
/ JD X485 Fuel thirsty #2
Mine is. /forums/images/graemlins/tongue.gif
/ JD X485 Fuel thirsty #3
At least your's is fuel injected. The carbureted ones really suck the fuel down.
John M
/ JD X485 Fuel thirsty #4
My X-575 is a gas hog, wish it was diesel. I will be selling it soon so that worry will be history..
/ JD X485 Fuel thirsty #5
What is "thirsty"?
For my X595 (diesel) I can run at WOT for one hour and use ~ .7gal.
I have only one complaint about the X595. That darn fuel level indicator is either 3/4 to full or about to run empty. There seems to be no middle (1/2 1/4 etc.)! /forums/images/graemlins/frown.gif
/ JD X485 Fuel thirsty #6
The X495 (Diesel) is the way to go. I replaced my 318 with it and I am very happy! I belive this mower will out last a couple mower decks and me.
/forums/images/graemlins/grin.gif
/ JD X485 Fuel thirsty #7
Yup, have 25 hours on an X585. It drinks a lot of gas. particullay with when PTO is engaged.
Should have bought a 2210, should have bought a 2210,should have bought a 2210,should have bought a 2210,..........
/ JD X485 Fuel thirsty #8
Guess I'm one of the few that isn't worried about the amount of fuel consumed by my X585. I have a 120' driveway to plow and 1.5 acres to mow. Before you tell me that I could have bought a smaller unit, please understand that I feel Tim Taylor is conservative.
/ JD X485 Fuel thirsty #9
My LX280 gas mower seems to be thirsty when compared to the things I've done with the bigger and heavier 4100 which is a diesel. Sure makes me think I should have gone with a diesel mower /forums/images/graemlins/smile.gif
/ JD X485 Fuel thirsty #10
Ditto. /forums/images/graemlins/grin.gif
I had a GX335 with the 20-hp Kawasaki before I got the X, and I was amazed (and alarmed /forums/images/graemlins/shocked.gif) at the amount of fuel it took. Now I can fill up with diesel and mow my 5 acres, then do odd-jobs (hauling with trailer, harrowing) for a week or so before I need to refill.
/ JD X485 Fuel thirsty #11
My 4010 uses 0.45 gallons/hr. Based on extensive data on automobiles, a carbureted model would use 50% more. A fuel-injected model would use only about 25% more. Otherwise, prorate on hp if nearly same weight or weight and hp if different weight. The 4010 is 18.5 hp and about 2600# with FEL and LX4.
If you're ever comparing automobiles/trucks, the above factors work, but mostly just on weight.
Ralph
/ JD X485 Fuel thirsty #12
</font><font color="blue" class="small">( I have only one complaint about the X595. That darn fuel level indicator is either 3/4 to full or about to run empty. There seems to be no middle )</font> Hey awlchu - Had kind'a the same problem with mine - except it read FULL all the time!! The dealer replaced the gauge package, but it still does the same thing!! Since it sips diesel at such a leisurely pace, I just make sure I fill up each time I mow, and, no prob's. That diesel's definitely the way to go.
Oops!! That has nothing to do with the original post. /forums/images/graemlins/blush.gif
/ JD X485 Fuel thirsty #13
I upgraded from a 335 20HP gas to a 355D 18HP. The rated fuel consumtion is half on the 'lil diesel. I'm sure the comparable X series engines are the same.
International 2000 End Loader (A66408)
International 2000...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
(10) Massey Ferguson Tractor Weights (A65640)
(10) Massey...
