JD X320 Observations
/ JD X320 Observations #1
tld
Boston, GA
JD 2025r
Had the X320 about three weeks now. Right at the 8 hour first oil/filter change. Here are several observations:
Seems as if it drinks a lot of fuel. Capacity is 3.3 galons. It takes that to mow 5 acres (mostly at top speed)..
It has a cruise control which I used one time. Today it doesn't work.
Has a rattle around the left guage wheen on deck. Drives me crazy.
Other than that it runs great.
/ JD X320 Observations #2
Have been thinking this might be my next mower. It's either that or a zero turn from deere. How'd you do for price and goodies from your dealer?
Sent from my LGL35G using TractorByNet
/ JD X320 Observations #3
Brand new gas engine using .66 gals/acre to mow the lawn seems about right. Can the dealer fix the cruise control? Have them check on the rattling while they are at it.
/ JD X320 Observations #4
Another way of putting it is that if you consider he is probably cutting a 42" wide path (with overlap using a 48" deck), then an acre is the same as mowing 2.35 miles in a straight line. At .66 gal per acre, that's about 3.6 mpg. Of course there's lots of variation in turning and grass height/density, but that gives you an idea of how much energy is being used to mow as compared to driving a car down the highway. A diesel engine in a mower would probably double or triple that efficiency. Neither Kawasaki nor Briggs & Stratton gasoline lawn mower engines are blue ribbon winners in the efficiency race.:rolleyes:
The mower itself (X320 with 54 inch deck and bumper was around $3200. It will go back sometime to fix the cruise and rattle but am afraid they will keep it for a week. Can't afford to do that with all the rain.
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
Frontier Forks (A64911)
Frontier Forks...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
x (A68191)
x (A68191)
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
