JD X320 Observations
/ JD X320 Observations #1
tld
Boston, GA
JD 2025r
Had the X320 about three weeks now. Right at the 8 hour first oil/filter change. Here are several observations:
Seems as if it drinks a lot of fuel. Capacity is 3.3 galons. It takes that to mow 5 acres (mostly at top speed)..
It has a cruise control which I used one time. Today it doesn't work.
Has a rattle around the left guage wheen on deck. Drives me crazy.
Other than that it runs great.
/ JD X320 Observations #2
Have been thinking this might be my next mower. It's either that or a zero turn from deere. How'd you do for price and goodies from your dealer?
Sent from my LGL35G using TractorByNet
/ JD X320 Observations #3
Brand new gas engine using .66 gals/acre to mow the lawn seems about right. Can the dealer fix the cruise control? Have them check on the rattling while they are at it.
/ JD X320 Observations #4
Another way of putting it is that if you consider he is probably cutting a 42" wide path (with overlap using a 48" deck), then an acre is the same as mowing 2.35 miles in a straight line. At .66 gal per acre, that's about 3.6 mpg. Of course there's lots of variation in turning and grass height/density, but that gives you an idea of how much energy is being used to mow as compared to driving a car down the highway. A diesel engine in a mower would probably double or triple that efficiency. Neither Kawasaki nor Briggs & Stratton gasoline lawn mower engines are blue ribbon winners in the efficiency race.:rolleyes:
The mower itself (X320 with 54 inch deck and bumper was around $3200. It will go back sometime to fix the cruise and rattle but am afraid they will keep it for a week. Can't afford to do that with all the rain.
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
2000 (INOPERABLE) KENWORTH T800 (A67714)
2000 (INOPERABLE)...
Turf Tiger Velocity Plus (A64557)
Turf Tiger...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
7ft Fork Extensions (A66734)
7ft Fork...
