y
JD RWA disc in need of a KK5971b bearing spool.
   / JD RWA disc in need of a KK5971b bearing spool. #1
rickgerek1
John Deere 3010
John Deere wants $130.00 and only source I can find on E-Bay wants $100.00 used. If you look at AGI supply they are not more then $30.00. The problem is finding the right size. I am willing to replace the hub and the spool but just cant seem to find anything that would work. The shaft is 1 and 1/8 inch square. The bearing is 7 inch and the hub holes must be 3 inch on center. Has anyone found a less costly used source on an aftermarket fix for these 1960's discs?
   / JD RWA disc in need of a KK5971b bearing spool. #2
I’m taking on the same disc restoration. My dealer told me they could get the gang bearings for about $60 if I remember correctly. They had access to an after market company that made a lot of JD bearings. When I get the information part numbers and all I’ll get back to you. If your still looking.
   / JD RWA disc in need of a KK5971b bearing spool. #3
farmer2009
I think rickgerek1 is referring to a white iron brg(KK5971B) not an anti-friction brg(AK3997B)
Thanks that would be great. I did a quick fix, cut two broken ones in half and slide them into the hub, but I don't know how long its going to last.
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
