JD Rotary Tiller - Jack Stand Bent/Issue
   / JD Rotary Tiller - Jack Stand Bent/Issue #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
My JD665 Rotary Tiller’s rear Jack stand got bent last evening when I went to put it away. :( Not the stand portion, but the plate that attaches to the tiller.
The plate must be soft metal, unfortunately. Does JD make a replacement attachment for this or should I attempt to bend it back myself? Just curious... Thanks!
-Bob
   / JD Rotary Tiller - Jack Stand Bent/Issue #2
A pic or three will help us answer your question..
   / JD Rotary Tiller - Jack Stand Bent/Issue #3
sounds like you want #38? Part# LVU14908 About $90 online
   / JD Rotary Tiller - Jack Stand Bent/Issue #4
JOHN DEERE BRACKET PART # LVU1498 | eBay
I see that part available unpainted on Ebay apparently as an aftermarket part. I guessing that there is a high demand for the part as I know, from experience, it is easy to forget to raise the support leg or tongue jack on any piece of equipment.
   / JD Rotary Tiller - Jack Stand Bent/Issue #5
I've got a 655 and it has two of those stands, front and back, on the same side. Both are unpainted (that includes the bracket).
   / JD Rotary Tiller - Jack Stand Bent/Issue #6
Bend it back and go about your day.
Thanks team. I did end up ordering the bracket - it was reasonable - and replaced it. I tried bending the other one back but was not successful. A new one was only $35 from the dealer.
I知 sorry, but I did not see your responses come to me via email - so I didn稚 get back here sooner.
Thanks again for all of your help!
-Bob
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
Top Hat Bumper Pull Trailer (A53117)
Top Hat Bumper...
