Planters JD Planter Question
/ JD Planter Question #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I bought an old JD 246/247 planter. It's in pretty rough shape and I'm doing some rebuilding and refurbishing. The chutes in which the fertilizer flows through to the ground are metal spiral cylinders. Both are rusted beyond repair. I have seen some rebuilt planters that have plastic tubes that replace the metal ones. Are those available through JD? Are they possibly aftermarket replacements? If so, any ideas about where they can be found? Any ideas/suggestions are appreciated.
kensfarm.........Shoup carries some aftermarket plastic ones, not too expensive, about $6.50 each. I assumed they were the answer, but after looking at the way they need to attach at the bottom, I'm not sure. Go over to ytmag.com and read a similar post in the implement alley forum to the one I posted here. There were some answers and suggestions that might be helpful.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
