JD OEM Hydraulic Caps, is $25 realistic?
   / JD OEM Hydraulic Caps, is $25 realistic? #1
marq
Romeo MI
03 JD 2210
OK, my JD hydraulic caps are in need of replacement, but the best price I see for a set of (8) colored caps is $25, seems high considering a couple pennies worth of material. Any alternatives/generics?
   / JD OEM Hydraulic Caps, is $25 realistic? #3
CA-plugs might have what you need.
   / JD OEM Hydraulic Caps, is $25 realistic? #4
I've been down the path before and there aren't really any cheap alternatives. The JD parts hold up pretty well so I would suggest you just swallow hard, pay the price and forget about it for the next 15 years or so.
   / JD OEM Hydraulic Caps, is $25 realistic? #5
As Kenny posted. Just pony the $25 up. I bought cheap caps for my Kubota, they lasted less than a year before they stretched out, shrunk or split.
   / JD OEM Hydraulic Caps, is $25 realistic? #6
At about $3.00 a piece, it does not appear JD is much higher than other suppliers on line.
   / JD OEM Hydraulic Caps, is $25 realistic? #7
Last time I check at TS they were $5/each. So $40 sounds reasonable.
   / JD OEM Hydraulic Caps, is $25 realistic? #8
Pioneer and Safeway caps are good quality also. However at $3.13 a piece for caps I would just buy them. That is stupid cheap for caps.
   / JD OEM Hydraulic Caps, is $25 realistic? #10
My JD ones didn't last as long as I figured they should. Got hard and brittle.
I would go to a hydraulic supplier and buy Parker or similar quality.
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
2023 Load Trailer (A55787)
2023 Load Trailer...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
Portable Restroom (A54865)
Portable Restroom...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55302)
2012 KINZE FLAT...
