JD OEM Hydraulic Caps, is $25 realistic?
   / JD OEM Hydraulic Caps, is $25 realistic? #1
marq
Romeo MI
03 JD 2210
OK, my JD hydraulic caps are in need of replacement, but the best price I see for a set of (8) colored caps is $25, seems high considering a couple pennies worth of material. Any alternatives/generics?
   / JD OEM Hydraulic Caps, is $25 realistic? #3
CA-plugs might have what you need.
   / JD OEM Hydraulic Caps, is $25 realistic? #4
I've been down the path before and there aren't really any cheap alternatives. The JD parts hold up pretty well so I would suggest you just swallow hard, pay the price and forget about it for the next 15 years or so.
   / JD OEM Hydraulic Caps, is $25 realistic? #5
As Kenny posted. Just pony the $25 up. I bought cheap caps for my Kubota, they lasted less than a year before they stretched out, shrunk or split.
   / JD OEM Hydraulic Caps, is $25 realistic? #6
At about $3.00 a piece, it does not appear JD is much higher than other suppliers on line.
   / JD OEM Hydraulic Caps, is $25 realistic? #7
Last time I check at TS they were $5/each. So $40 sounds reasonable.
   / JD OEM Hydraulic Caps, is $25 realistic? #8
Pioneer and Safeway caps are good quality also. However at $3.13 a piece for caps I would just buy them. That is stupid cheap for caps.
   / JD OEM Hydraulic Caps, is $25 realistic? #10
My JD ones didn't last as long as I figured they should. Got hard and brittle.
I would go to a hydraulic supplier and buy Parker or similar quality.
New/Unused 20ft Bi-Parting Iron Gate (A54865)
New/Unused 20ft...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A56129)
2019 TEREX PHOENIX...
City of Lakeland (A51691)
City of Lakeland...
2018 JLG T350 PORTABLE ELECTRIC MANLIFT (A52706)
2018 JLG T350...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
