JD OEM Hydraulic Caps, is $25 realistic?
   / JD OEM Hydraulic Caps, is $25 realistic? #1
marq
Romeo MI
03 JD 2210
OK, my JD hydraulic caps are in need of replacement, but the best price I see for a set of (8) colored caps is $25, seems high considering a couple pennies worth of material. Any alternatives/generics?
   / JD OEM Hydraulic Caps, is $25 realistic? #3
CA-plugs might have what you need.
   / JD OEM Hydraulic Caps, is $25 realistic? #4
I've been down the path before and there aren't really any cheap alternatives. The JD parts hold up pretty well so I would suggest you just swallow hard, pay the price and forget about it for the next 15 years or so.
   / JD OEM Hydraulic Caps, is $25 realistic? #5
As Kenny posted. Just pony the $25 up. I bought cheap caps for my Kubota, they lasted less than a year before they stretched out, shrunk or split.
   / JD OEM Hydraulic Caps, is $25 realistic? #6
At about $3.00 a piece, it does not appear JD is much higher than other suppliers on line.
   / JD OEM Hydraulic Caps, is $25 realistic? #7
Last time I check at TS they were $5/each. So $40 sounds reasonable.
   / JD OEM Hydraulic Caps, is $25 realistic? #8
Pioneer and Safeway caps are good quality also. However at $3.13 a piece for caps I would just buy them. That is stupid cheap for caps.
   / JD OEM Hydraulic Caps, is $25 realistic? #10
My JD ones didn't last as long as I figured they should. Got hard and brittle.
I would go to a hydraulic supplier and buy Parker or similar quality.
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
Decorative Metal Butterfly (A55758)
Decorative Metal...
2020 KUBOTA SVL75-2 SKID STEER (A52706)
2020 KUBOTA...
Peterbilt (A51692)
Peterbilt (A51692)
