JD LT150 Safety Switch Problem
/ JD LT150 Safety Switch Problem #1
Skidmark25
North Shore, MA
B7610
Hi all,
I have a JD LT150 bought brand new around 7 or 8 years ago. Never had a problem with it until now.
Tractor starts fine with the foot brake locked but when I let off the brake the engine stalls out. I can start the engine, then unplug the foot brake safety switch and I am able to let off the brake and move the mower which leads me to belive that it is some sort of safety switch issue..
Here are some symptoms:
Last fall (5 months ago) my stupid brother broke the front plastic bumper so I had the hood / cowl completely off to replace the broken plastic. At that time I may have disturbed some type of hood safety switch that I can not find.
I replaced the brake safety switch and the seat switch already (these were cheap so it wasn't a big deal)
I also looked for frayed / chafed wires under the hood and found none.
Any ideas where I should look next?
/ JD LT150 Safety Switch Problem #2
I might be able to give you assistance on rhis. There is no saftey switch that connects to the hood so your brother is off the hook. What I've seen more than once is the wires for the seat switch that go along the right fender support become frayed because of contact with brake linkage, belt ect. Take a look there and you might solve your problem. Good luck
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2016 JOHN DEERE 317G SKID STEER (A64279)
2016 JOHN DEERE...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
Brown 6' Tree Cutter (A64119)
Brown 6' Tree...
EZ Trail 3400 (A63688)
