JD Loader for 4320
/ JD Loader for 4320 #1
n219ct
Essex, MA
JD 4320
Hello,
I have a 2005 JD 4320 and I am trying to decide on whether to get the 400x loader or the 400cx loader. I am going to put the skid steer attachment on it so that I can use my Bobcat attachments.
Is the cx worth the price difference?
Thanks
/ JD Loader for 4320 #2
Yes, all CX loaders are stronger than the X. i would get the CX. thats what i did.
and if i am not mistaken . All CX loaders are quick tach and come off.
I think the X loader is designed to stay on all the time. at least that is my understanding.....:)
/ JD Loader for 4320 #3
n219ct said:
Hello,
Thanks
Welcome too TBN:D
Get the 400CX, besides having more lift capacity and lift height, it's also self leveling.
So it a word, to answer your question, YES:D
/ JD Loader for 4320 #4
I don't think that is true...I think the X loader detaches from the tractor the same way. Heck, they share the same manual.
I think I would have been disappointed if I had less lift capacity.
The self-leveling feature is really slick too.
/ JD Loader for 4320 #6
You won't be disappointed with the 400cx! I wish they had the skid steer plate as on option when I got mine! I do have the JD forks and 4-in-1 for mine, and I love it!
/ JD Loader for 4320 #7
I am happy with my 400X, although I did get the heavy duty bucket. The CX must have larger cylinders than the X to have a higher lift weight capacity. Larger cylinders do not lift as fast as smaller ones fed by the same pump, so score one for the X. I can see that the self leveling feature would be nice for novices but not so necessary as you gain experience. The joystick control on the X works well and I don't have much trouble keeping a load level. With a material bucket, it is nice that the bucket tilts back when lifted as it minimizes spillage.
/ JD Loader for 4320 #8
Actually, the 400CX loader uses different leverage points compared to the 400X loader to give it the extra lift capacity.
Thanks for all the replies. . .
I already ordered the 400x but I am going to call tomorrow and try to change to the CX -- given that's it's more money I hope they will honor the request...
Now the next question: should I get the imatch for the 3pt hitch?
Thanks again
/ JD Loader for 4320 #10
Thanks again
it is an absolute must. you will be sorry if you dont.
its great.....:)
Thanks -- you guys are great.
I changed my order today and got the 400cx (with the skid steer attachment, and the extra hydraulics with skid steer flat couplers), and I ordered the imatch.
I can't wait!
the only drawback that I can is that the skid steer bucket probably comes in black not green -- I'm going to have to paint it.
Another question. . .
Is there a way to bypass the self leveling if there is a need to tilt the bucket while it is raised?
Thanks
/ JD Loader for 4320 #14
...no, there is not a way to disengauge the self leveling feature....but it has never been a problem!
/ JD Loader for 4320 #15
Oh, and I have a black bucket, but is looks fine on the tractor.....
/ JD Loader for 4320 #16
Thanks
Your thinking seams to be the same as mine when I first started looking at the JD's with the cx loaders. The self leveling feature is not controlled hydraulically. There is a set of linkage cams, I'll call them, on top of the loader arms that pivot the bucket as you raise and lower the loader arms (see pictures of the cx vs. the x). The design of the geometry with the linkage cams keeps the buck in the same relative position when raising and lowering the loader. You can of course dump or curl the bucket hydraulically at any position. Go to your JD dealer and drive one in the lot. You'll see what I mean.
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2018 INTERNATIONAL LT625 (A67714)
2018 INTERNATIONAL...
