JD L130 Question
/ JD L130 Question #1
diekruzen
Hello All,
Last year I bought a L130 and pretty much ever since purchasing, the tractor backfires when you turn it off. The engine stops, you wait for about 5 seconds and BANG. I contacted the store where I bought it because it was scheduled to be 'winterized' and asked them why I get constantly get backfires. He said that sometimes backfires happen and it is normal. I find that highly unlikely since the Kubota, Cub Cadet, and Deere owning neighbors I have do not have the problem.
Any thoughts on what is happening? Anything info would be appreciated. I just want some 'ammo' when I call the dealer again.
TIA,
Pete
/ JD L130 Question #2
I have a LT133 and can make it backfire consistantly by turning it off with it throttled up. Does your tractor idle high?
/ JD L130 Question
Hello DHennet,
Hmm. I move the throttle level down to the botton every time I cut the engine. I'm not sure if my tractor idles high, I really don't have anything to compare it to.
Thanks again for the response.
/ JD L130 Question #4
Hi,
My L120 used to backfire bad on shutdown. moving the throttle to lowest position before turning off really did address it - not really a fix, but it doesn't scare everyone either.
/ JD L130 Question #5
Try experimenting with the throttle. I shut down my B&S at full throttle. No backfire. Some have said a medium throttle has worked. Others at minimum throttle.
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2014 Mitsubishi Outlander (A61574)
2014 Mitsubishi...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
1067 (A63291)
1067 (A63291)
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
