JD L130 cutting off under load
/ JD L130 cutting off under load #1
KTKelly
Oak Island, NC
JD L130
Bit of a puzzle.
MY L130 will fire up and run great. Until I engage the blades.
At that point it may run for 5 to 10 minutes, or it may almost immediately shut down.
I presume it's a bad switch, but am not sure which one would be the culprit.
Details:
1. The RIO switch doesn't seem to work at all, so I am going to use a simple jumper to bypass it.
2. I haven't tested the seat switch, and I wouldn't mind bypassing it, but I would need to know which wires to jumper (there are three to the switch - One black with a black jumper to the ext position, and then two black with white stripe).
3. I don't suspect the PTO switch, or the PTO itself, as the blades will engage, and will run for at least a short time (it varies).
Any other switches that could be at fault? I'd rather not take it to the dealer and pay through the nose to get a 10 year old mower repaired...:(
Thanks in advance....
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2016 FORD F250 EXTENDED CAB PICKUP TRUCK (A66091)
2016 FORD F250...
PT 1100 Gal Supply Tank (A64911)
PT 1100 Gal Supply...
2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2015 John Deere 6115M (A64911)
2015 John Deere...
