JD GX85 riding mower -- Should bendix gear be lubed or kept dry?
   / JD GX85 riding mower -- Should bendix gear be lubed or kept dry? #1
Gene123
Dallas. TX
John Deere SRX75, John Deere GX85
Does the bendix gear need to be lubed, or should it be installed dry? It's plastic, and the shaft it rides on is plastic.
   / JD GX85 riding mower -- Should bendix gear be lubed or kept dry? #2
I assume that you are talking about the gear on the starter.
Plastic gears should not need lube. If you have the starter disassembled, cleaning up the shaft and the inside of the gear is all you should need to do.
If it is acting up and not engaging properly, just a shot of carb cleaner should do the job and you should not have to disassemble.
Richard
Thanks, Richard. This helps.
2021 KOMATSU D39PX-24 CRAWLER DOZER (A52705)
2021 KOMATSU...
2007 Kenworth (A55788)
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
