JD GX85 riding mower -- Should bendix gear be lubed or kept dry?
   / JD GX85 riding mower -- Should bendix gear be lubed or kept dry? #1
Gene123
Dallas. TX
John Deere SRX75, John Deere GX85
Does the bendix gear need to be lubed, or should it be installed dry? It's plastic, and the shaft it rides on is plastic.
   / JD GX85 riding mower -- Should bendix gear be lubed or kept dry? #2
I assume that you are talking about the gear on the starter.
Plastic gears should not need lube. If you have the starter disassembled, cleaning up the shaft and the inside of the gear is all you should need to do.
If it is acting up and not engaging properly, just a shot of carb cleaner should do the job and you should not have to disassemble.
Richard
Thanks, Richard. This helps.
LANDPRIDE RCR1260 - 5' ROTARY MOWER (A54756)
LANDPRIDE RCR1260...
UNUSED 3 STEP - STEP LADDER (A54757)
UNUSED 3 STEP -...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2019 FREIGHTLINER CASCADIA SLEEPER (A54607)
2019 FREIGHTLINER...
