JD GX345 smoking ?
   / JD GX345 smoking ? #1
Rebs
Niagara Falls, NY
JD 175
I am getting what appears to be oil coming out the exhaust pipe on the left cylinder of my JD. It smokes and burns off but doesn't do it every time I mow.
Does anyone have any idea's what could be wrong ? There is 650 hrs on the mower
After a closer look it appears the oil is not coming out of the exhaust but maybe a bad valve cover gasket. Has anyone had this problem ?
   / JD GX345 smoking ? #2
More then likely it is the valve cover the gasket gets hard and starts cracking letting the oil leak out. It usually doesn't leak alot bout just enough to make it smoke
   / JD GX345 smoking ? #3
I have had this happen on mine also it is the over head valve gasket. It is easy to change you just need to get the gasket
Thank you for your replies, I appreciate it.
   / JD GX345 smoking ? #5
Same thing on my 345. I have replaced the valve cover o-rings many times. There are 2 designs:
- the "original" design is just an inexpensive o-ring that is formed to fit in the groove in the plastic valve cover
- the "new" design is a metal valve cover with a special flat gasket underneath it
The new design is much more expensive but lasts longer. Since yours is a GX345 you may already have the new design valve cover and only need the gasket ...
I picked up the gasket today its like a small o ring, I was not lucky enough to have the good ones
2016 Chevrolet Traverse 2LT SUV (A48082)
2016 Chevrolet...
2016 Ford F-450 Knapheide Service Truck with Liftgate (A48081)
2016 Ford F-450...
2014 Dodge Ram 1500 Pickup Truck (A50860)
2014 Dodge Ram...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2004 Ford F-750 Crew Cab Wrecker Tow Truck (A48081)
2004 Ford F-750...
2017 International DuraStar 4300 Cab and Chassis Truck (A48081)
2017 International...
