JD GT235 Snowthrower
/ JD GT235 Snowthrower #1
kdkerns
Does anyone else have experience with these 42 inch JD "Snowthrowers"?
I bought a used one in October and am less than pleased with the performance. It ended up plowing more snow than throwing it. When it did throw, it was mainly throwing it on top of the machine. It mainly got clogged. I sprayed the chute area with silicon spray and that delayed the clogging, but throwing perfomance was still not improved.
The snow here in Northern Va today was wet and heavy. My guess is that thes machines are good with the light powdery stuff and useless with the wet heavy stuff. Any ideas?
** This post is mine and only my ideas, thoughts, etc.**
/ JD GT235 Snowthrower #2
Years ago, I had a JD 140 [14hp Kohler, hydrostatic] with a 42" snowblower. I lived on a lake with about 1/3 of a mile of private road. Probably simular to the blower on the front of your tractor. I kept the road open year round with that little blower, drifted snow off the lake and all, and it worked fine. Blowers do not work very well moving slush, especially the single auger ones. To help it out, keep the engine RPM up. It should work fine once you get some real snow. Hang in there.... :)
/ JD GT235 Snowthrower #3
I have been snowblowing for 25 years where we get 20 to 30 feet of snow each year. Most of time it is cold and the has little moisture content. When it is wet and heavy, even good blowers bog down.
I haven't used the one you mentioned but I have experienced the symptoms you mentioned with good blowers, so don't give up on it just yet.
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61572)
Pallet of...
