Buy an existing JD 2020 or wait for newer?
   / Buy an existing JD 2020 or wait for newer?
My JD 2030 diesel has independent PTO, JD 245 MSL loader, 2 rear SCVs, extendable lower links on the 3pt hitch, HD front axle 11L-15 tires, HI/LO shift.
If someone were to offer me $12K they would own it.
That looks and sounds nearly perfect for what I'm looking for. I really like the size!
4WD would be nice, but I could get around it with chains. I would be driving over to look at and probably buy that thing if it were even reasonably close.
Out here we can't even find those, and if we did we'd be looking at least $15,000+ . I've thought about buying from the right side of the USA and shipping it out here, but they want $4,000 to $5,500 to ship them.
I've used an old Ford industrial backhoe as a loader for years. I think it's a mid 1960s era machine. It's 2WD, power steering, and fairly worn. I've never had a bit of problem with the steering or 2WD on it. I also don't use a loader very heavily though, just occasionally loading and unloading equipment. Engines, sheet metal equipment, brakes, shears, rolls, etc. Maybe lift the box off a truck or something.
Just to give you guys an idea of what I have to pick through, here's my local Craigslist search:
Craiglist Search Link, Tractor Loader
The only thing that will work is a Ford/NH 4630 4WD that they want $21,500 for. Massively overpriced I think.
NH 4630 4WD
I'm going to keep searching, it's actually a fairly relaxing ritual at the end of the day. I'll probably end up either waiting until this winter to buy something, or buying a trailer (which I need anyway) and driving across the country to get something. Or both.
-----Edit-------
And here's tractorhouse links for Oregon and Washington.
TractorHouse WA
and
Tractorhouse Oregon
There's at least the 2255 in Oregon, but it's got over 11,000 hours on it. It's been on there for months.
   / Buy an existing JD 2020 or wait for newer? #22
I have the same trouble with the independent PTO engagement lever popping out of engagement. JD should have put a heavier detent on it.
Your picture shows the swept back axle. Great for manuverablity, but NOT what you want for a loader. A std straight axle would be better, the HD with two rows of "knee" bolts the best. You also NEED side frames for a loader.. Notice the cost new!
I know what you mean about too far. Seems everything that interests me is too much or too far away.
In your pictures (original poster) that 2020 has the guard for the fuel and radiator caps. First I ever saw one, other than in the parts catalog. I am also seeing what looks like a 70s Ford truck?
   / Buy an existing JD 2020 or wait for newer? #23
Forgot to say it looks like you have the down exhaust, like my 2030 has. I like it, only drawback is hooking with the engine running it makes my eyes water. and if you ever need a new hood they are harder to find.
   / Buy an existing JD 2020 or wait for newer? #24
You can still buy the shift legend sticker/decal/label
Ah thanks for all the info. I'll pass the label info on to dad.
It is actually a vertical exhaust. In the first picture it looks like a post, but it's the muffler, just behind the fill cap guard.
I grew up using his Massey TO 35 with the down exhaust. I've spent a lot of time eating that exhaust while trying to hook up. I suppose we should have put a 90 in the exhaust and have it dump to the side instead of straight back.
Dad and I live right next door to each other, and I'm usually the one that mows for him as he gets older.
Good eye on the Ford, it's mine. It's a 1979 Ford F-250 2WD with a 460 and factory Air Conditioning. One of these days I'll get around to straightening out a few dents and painting it. It's been a great truck.
I also have a 1977 Ford F-250 4x4 with a 460 with a ZF5 5 speed that I mated that I'm restoring. It's a great, straight truck.
This whole tractor thing actually started because of a Dentside Ford. He was pulling his tractor on his trailer down about 4 miles to another piece of property to mow it, and a kid ran a stop sign and dad totalled his truck, trailer, and tractor. So he's had to get a replacement tractor, which is how he got the JD 2020. Fortunately everyone came out of the wreck okay.
His truck is a restored 1978 F-250 Extended Cab 4x4 Ranger XLT Trailer Special with 460 and automatic. He loved that truck and had about $30,000 into it. He got some money out of it from the insurance, but not as much as he should have. He actually has it on Ebay right now, I think the auction ends tonight. It's a beautiful truck except for the front end damage. Pretty sad to see it like this. He could fix it but he just doesn't want to look at it again.
Ebay listing
I just came across this. He'll deliver it to me, but it's a 9 hour drive for me to go look at it. Not a 4WD, but that's not a necessity, just a want. I would really like to get a tractor soon if I can find one, as my property is for sale and I need a machine to move my equipment. I could rent, but it would be nice to find one.
It's on facebook, which I know not everyone has, so I'll just put the pictures up here.
He's not sure of the hours, the glass is fogged over from the sun. He's going to try and clean it up and get back to me with the hours.
It looks like it has 2 remotes at the rear that aren't used for the loader. Am I wrong or are the front axles swept back?
I'm having a hard time finding stats on a JD 145 loader. Not sure what the capacity on it is.
Any opinions?
"1979 JD 2240 with loader and Gannon box. Runs great and everything works."
   / Buy an existing JD 2020 or wait for newer? #28
Any opinions?
View attachment 703514View attachment 703515View attachment 703516View attachment 703517
Advertised lift capacity on the JD 145 series loader is 2,100 lbs, and on the 148 series 2,400 lbs.
   / Buy an existing JD 2020 or wait for newer? #30
The 2240 looks like it has the swept back front axle, but hard to tell from the angle of the pictures.
It doe not appear to have side frames, but hard to tell.
It does have wheel weights! (y)
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
30ft Highway Trailer Co. Lowboy (A56438)
30ft Highway...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
