JD Differential Lock Upgrade??
/ JD Differential Lock Upgrade?? #2
Check with the parts counter at your Deere dealer too. They should know right off the bat.
My suspicion would be they wouldn't. Just too expensive to offer, and I'd think the transmission would be too much an integral part of the picture to be 'either/or' for such an option to be added.
Good luck. /forums/images/graemlins/wink.gif
/ JD Differential Lock Upgrade?? #3
I doubt if JD would provide it but those GTs use trannys from the same mfg. (I bet I'm going to spell this wrong but I think it's "Kanzai") as a lot of other companies use. If you do some "googling" you'll find that sometimes there were optional versions of essentially the same oem diff used depending on final brand/model of tractor. You might find something that was done for someone other than JD if you investigate back through the oem but you'd be on your own as far as installation/repairs/making it work.
Or you could trade it in on an X-series. Depending on much you value your time it might be cheaper! /forums/images/graemlins/grin.gif
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
New/Unused Electric Winch (A65583)
New/Unused...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2025 AGT Industrial MX-MRT14 (A64127)
2025 AGT...
