JD Differential Lock Upgrade??
/ JD Differential Lock Upgrade?? #2
Check with the parts counter at your Deere dealer too. They should know right off the bat.
My suspicion would be they wouldn't. Just too expensive to offer, and I'd think the transmission would be too much an integral part of the picture to be 'either/or' for such an option to be added.
Good luck. /forums/images/graemlins/wink.gif
/ JD Differential Lock Upgrade?? #3
I doubt if JD would provide it but those GTs use trannys from the same mfg. (I bet I'm going to spell this wrong but I think it's "Kanzai") as a lot of other companies use. If you do some "googling" you'll find that sometimes there were optional versions of essentially the same oem diff used depending on final brand/model of tractor. You might find something that was done for someone other than JD if you investigate back through the oem but you'd be on your own as far as installation/repairs/making it work.
Or you could trade it in on an X-series. Depending on much you value your time it might be cheaper! /forums/images/graemlins/grin.gif
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2011 Caterpillar 420E Backhoe (A64194)
2011 Caterpillar...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
