Ballast JD Ballast Boxes - i-Match compatible?
/ JD Ballast Boxes - i-Match compatible? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
I have a JD-ballast box that doesn't seem to be compatible with my i-Match unit. Anyone know if there is a conversion kit for the ballast box that allows it to work with the i-Match? Or are ballast boxes inherently non-compatible?
I bought the box from the dealer several years ago and recently bought the i-Match.. every other implement fits fine except for this and it's a JD unit....
Thanks!
-Bob
/ JD Ballast Boxes - i-Match compatible? #2
Here is a picture showing the JD ballast box using I-match. All you need is a Bushing kit and it will work just fine.
JD BallastBox with I-Match
/ JD Ballast Boxes - i-Match compatible? #3
The JD ballast boxes manufactured prior to the introduction of I-Match are incompatible with I-Match. I had one that I had to trade in for the newer style when I purchased an I-Match for use on a 955.
JackIL
/ JD Ballast Boxes - i-Match compatible? #4
JackIL
This is correct. My freind has an older one that we had to do some surgery on to make it compatible.
Then I probably have the older one also. What kind of surgery did you do?
I'm going to give my dealer a call and see what they say. It kinda makes you mad that they don't fit when JD has had the i-Match around for quite some time.
BTW, mine was bought in 2003 so I suspect that qualifies for the older model.
-Bob
/ JD Ballast Boxes - i-Match compatible? #6
We took some 3" x 1/2" flat bar and remade the upper mount higher so the hook would fit. Kind of like what you see in the picture posted above.
You probably got one of the older ones when they were making the transition to the new style. Maybe you can sell your BB locally to recoup some money, or use this as a opportunity to get a welder:D
/ JD Ballast Boxes - i-Match compatible? #7
Rmonio, Do you have a picture of yours? A model from 2003 does not seem that old to me.
Yes, I have some pictures of the ballast box. Here they are.
Is this the older unit? If it is, how do I modify it to work?
(still makes me mad that JD dealers were selling ones that weren't i-Match compatible... :mad: )
-Bob
/ JD Ballast Boxes - i-Match compatible? #9
Definately looks like the old model all right. Do you have a welder and sawzall? Measure the distance from the top link pin to the side arm pins. Let us know that that is. May be a simple mod of cutting the box below the top link pin enough to get the hook in. You will still need the bushing kit forr JD or from F&F or TSC. Check out the pick in my reply above for pictures of how the newer one works.
I don't have a welder, but I do know a few people that do. In the interim I'm going to talk to my dealer and find out why they sold me the old one and/or what can be done.
Thanks for the help!
-Bob
/ JD Ballast Boxes - i-Match compatible? #11
WOW thats definately an old style, because I had the first 2210 that our dealer ever received and it came with the NEW style ballast box. :)
Well, I bought the 4600 before the 2210's came out and it was about a year later that I got the Ballast Box (just when the new 2210's were coming out). I suspect I might have got something that was in the "inventory" and hence it hadn't been updated yet.
I'll talk to the Dealer tomorrow... if it can be retrofited with some welding we'll "git'er done".. :mad: ;)
-Bob
Well, talked to the dealer today and it is indeed the older box. They said they would fix it for me though with a welder and some green paint when I bring my 4600 in for it's 500 hour service checkup... So I guess I'm happy with the outcome for now.
But you'd think they would have figured this out when they were selling the Ballast Box originally.... :( :mad:
-Bob
/ JD Ballast Boxes - i-Match compatible? #14
-Bob
To be fair to the dealer, they probably would have got you the right one had you bought the I-Match at the same time as the box. But not matter now, sounds like they are going to fix you up. Sounds like a good dealer:D
Yes, they are a good dealer and they have treated me right in the past. So I'm happy.
But the irony of the matter is that i-Match technology has been around for quite some time. It was only when the compact tractor market kicked in that they became really popular and hence I suspect the retrofitting of products became an issue. Oh well.... we'll get it fixed...
-Bob
/ JD Ballast Boxes - i-Match compatible? #16
I have seen soime crazy CAT 3 and larger Quick Hitches on some big boy Deeres. They were not called Imatch but these quick hitches were crazy looking and very very big. I think once you get into some major equipment $$ things like that are just included. Nothing to add on.
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
208315 (A58376)
208315 (A58376)
