JD 990 Driving at full Speed with 1.5 hours
   / JD 990 Driving at full Speed with 1.5 hours #1
sandtopia
I have a John Deere 990 with only 1.5 hours. I am taking it to my grandfather's house which is about 10 miles. Is it too early to put it in the highest gear and go? I guess it would be 9th gear. I have been reading about breaking in the engine but was wondering if it would hurt anything to go at the top speed for 10 miles.
Your opinions would be great. I am loving this tractor. I haven't spent much time on it yet because of my job but am looking forward to the weekend.
   / JD 990 Driving at full Speed with 1.5 hours #2
Just don't leave the RPM the same all the way. Vary it up and down some and you will be fine.
   / JD 990 Driving at full Speed with 1.5 hours #3
Just as Jerry said, don't run the whole trip at one RPM setting.
And BE CAREFULL, 10 miles is a long trip on the tractor!
   / JD 990 Driving at full Speed with 1.5 hours #4
Tractor motors are meant to run at XXXX rpms (what ever gives you 540 pto rpms). Put her in gear and go at those rpm's. Ideally you would want to drive it with a load, like pulling a trailer with stuff in it, but going empty is ok. Tractor motors are like weed trimmer, chainsaw, generator, ect... motors, not like car motors where one day your uptown shopping, and the next your playing Mario Andretti on the freeway alway's shifting through gears with varying rpm's.
   / JD 990 Driving at full Speed with 1.5 hours #5
With only 1.5 hours you definitely have to vary the RPM's. I wouldn't run it full out for an extended period until the rings are seated and all the other gears such as in axles etc are mated. It takes a good 50 hours to break a new tractor in and they are the most critical hours put on the tractor. Just my opinion..........Go slow, vary the Rpm's and all should be fine....
   / JD 990 Driving at full Speed with 1.5 hours #6
While this is very true for a engine that is broken in, the engine in question is brand new, with only 1.5 hrs on the clock. Proper break-in procedures early on will ensure a long engine life.
   / JD 990 Driving at full Speed with 1.5 hours #7
10 miles--Do you have insurance?
My home owners cover me only for at home.
I had to take out inland marine insurance. It was quite pricey for that machine around 350 per month.
   / JD 990 Driving at full Speed with 1.5 hours #9
In '61 grandpa got to tour the Deere plant in Iowa where they made his 4010. The tractors came out the door, literally, at WOT. This was after they were dynoed at WOT to make sure they worked. Your tractor motor is more broke in at the factory than you think.
So, my question is, that I already know the answer to, is.... If the motor is meant to run at a given rpm, why does it need to be "broke in" at other rpm 's???
Let's put this in perspective another way. If your car averages 45 miles per hour of use, in 5000 hours, you will have driven about 225,000 miles. The typical ag diesel is rated for 5000 hours. That is equal to the life of a typical car...if not more becouse of the harsh conditions an ag motor encounters in dusty/muddy/alway's heavily loaded, conditions. Now your car must accelerate up to various speeds, with various throttle settings all the time. Some day's you might just go to the store with a light foot, and only rev the motor up to say 2700 rpms, during the week, say, 3 day's a week, your running late for work, so you drive harder, now your reving your motor up to 3600 rpm's. In both cases, the motor is going up and down in rpm's, while the transmission (or operator) is shifting gears. In this case, the motor needs to be broken in for the various rpm ranges the motor will encounter over it's life. A properly operated tractor should see the same rpm's at a minimum of 80% of it's life. You need the motor "broke in" in it's optimum operating rpms, so you get maximum hp once the rings are finished "seating". I'm not out to debate the issue, I'm just giving more of an explanation on why I stated what I did in my first post.
   / JD 990 Driving at full Speed with 1.5 hours #10
Just maybe things has changed since 1961, that is 45 years ago, and most things has. But either way, by changing the rpms you are also changing the temperature of the rings, and cylinder, so they will wear better to make a better fit. Now this isn't just something all the company's are dreaming up, just to have something to do. They have proven this works, to make the engine work better and last longer. Why do you think they put in break in oil in them? Not just to have something to do, but to help them break in better.
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
