JD 990 Driving at full Speed with 1.5 hours
   / JD 990 Driving at full Speed with 1.5 hours #21
I guess you are young and like a lot of young guys you think you know all the answers, you will learn as you get older, everyone does. Loading the tractor or in other words putting it under load, does not force the rings against the walls, at all. They are spring loaded so to speak at I would guess around 15 pounds, and you don't force them to do anything, except to go up and down with the piston at a different rpm. They will keep the same pressure on the walls, unless you would got them hot enough to lose temper, then of course they would have a lot less. You need to know that just because you think you know something, that doesn't make it fact. What I'm saying is a proven fact, and its just the way it works.
   / JD 990 Driving at full Speed with 1.5 hours #22
My JD990 Owner's Manual says nothing about engine break-in procedure.
If JD felt it were still relevant, wouldn't they include it in the manual?
FWIW, with automobiles, manufacturer's instructions on engine break-in disappeared back in the early 70's.
   / JD 990 Driving at full Speed with 1.5 hours #23
True. However, most small engines still come with break in instructions. Must be a reason, but I'll not venture a guess until this thread calmes down a bit. :)
   / JD 990 Driving at full Speed with 1.5 hours #24
You just don't give up do you. No, I'm not a young person who knows everything. I have been building motors since about 1979. I have received engine repair certification from 7 different engine makers.
Hastings engine break in procedure:
Make a test run at 30 miles per hour and accelerate at full throttle to 50 miles per hour. Repeat the acceleration cycle from 30 to 50 miles per hour at least ten times. No further break-in is necessary. If traffic conditions will not permit this procedure, accelerate the engine rapidly several times through the intermediate gears during the check run. The object is to apply a load to the engine for short periods of time and in rapid succession soon after engine warm up. This action thrusts the piston rings against the cylinder wall with increased pressure and results in accelerated ring seating.
A bike engine break in procedure:
When a cylinder is new or overhauled the surface of it's walls are honed with abrasive stones to produce a rough surface that will help wear the piston rings in. This roughing up of the surface is known as "cross-hatching". A cylinder wall that has been properly "cross hatched" has a series of minute peaks and valleys cut into its surface. The face or portion of the piston ring that interfaces with the cross hatched cylinder wall is tapered to allow only a small portion of the ring to contact the honed cylinder wall. When the engine is operated, the tapered portion of the face of the piston ring rubs against the coarse surface of the cylinder wall causing wear on both objects.
Each tiny groove acts as the oil reservoir holding oil up to the top level of the groove where it then spreads over the peak surface. The piston ring must travel up and down over this grooved surface, and must "hydroplane" on the oil film retained by the grooves. Otherwise, the ring would make metal-to-metal contact with the cylinder wall and the cylinder would quickly wear out.
However the ring will only ride on this film of oil if there is sufficient surface area to support the ring on the oil. When the cylinders are freshly honed the peaks are sharp with little surface area. Our goal when seating the rings on new steel cylinders is to flatten out these peaks to give more surface area to support the rings, while leaving the bottom of the groove intact to hold enough oil to keep the surface of the cylinder wet with oil. At the point where the top of the peaks produced by the honing operation become smooth and the tapered portion of the piston ring wears flat break in has occurred.
When the engine is operating, a force known as Break Mean Effective Pressure or B.M.E.P is generated within the combustion chamber. B.M.E.P. is the resultant force produced from the controlled burning of the fuel air mixture that the engine runs on. The higher the power setting the engine is running at, the higher the B.M.E.P. is and conversely as the power setting is lowered the B.M.E.P. becomes less.
B.M.E.P is an important part of the break in process. When the engine is running, B.M.E.P. is present in the cylinder behind the piston rings and it's force pushes the piston ring outward against the coarse honed cylinder wall. Piston rings are designed to take advantage of the pressure and us it to push the rings out against the cylinder wall. Therefore, as pressure builds during the compression stroke, the rings are pushed harder against the cylinder wall which aids in seating the rings.
   / JD 990 Driving at full Speed with 1.5 hours #25
Your engine will be fine. I have yet to hear of engine failure due to improper break in. I have a 990 and did not do anything special for break in. I am confident that my machllne will last a lifetime. I would be more concerned with the tires. Dont run in 4WD.
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2023 JOHN DEERE 317G SKID STEER (A51242)
2023 JOHN DEERE...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
