JD 970 won't shift into gear
   / JD 970 won't shift into gear #1
MidTNDawg
after starting the engine. Transmission shifts fine with engine off. I assume a clutch problem. Any help / suggestions will be appreciated.
   / JD 970 won't shift into gear #2
Your diagnosis is most likely a correct one... Have you tried adjusting the clutch? Tractor been sitting for a spell? How much "free play" is there in the pedal travel?
AKfish
   / JD 970 won't shift into gear #3
If you could get tractor in an open area. If clutch plate is stuck and you get it started "SAFELY" in gear with clutch pedal depressed and alternately stomp brake pedals the clutch might come unstuck.
   / JD 970 won't shift into gear #4
I have a 970 and experienced the same problem. When the tractor sets up the clutch disc sticks to the flywheel and will not release. I took the side inspection cover off and spayed clutch with kroil and let it sit overnight. The next morning it was free, though sometimes you might need to put the tractor against a tree and start it.
John Deere 637 Disk (A50514)
John Deere 637...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
Unused Delta Crash...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
