JD 970 won't shift into gear
   / JD 970 won't shift into gear #1
MidTNDawg
after starting the engine. Transmission shifts fine with engine off. I assume a clutch problem. Any help / suggestions will be appreciated.
   / JD 970 won't shift into gear #2
Your diagnosis is most likely a correct one... Have you tried adjusting the clutch? Tractor been sitting for a spell? How much "free play" is there in the pedal travel?
AKfish
   / JD 970 won't shift into gear #3
If you could get tractor in an open area. If clutch plate is stuck and you get it started "SAFELY" in gear with clutch pedal depressed and alternately stomp brake pedals the clutch might come unstuck.
   / JD 970 won't shift into gear #4
I have a 970 and experienced the same problem. When the tractor sets up the clutch disc sticks to the flywheel and will not release. I took the side inspection cover off and spayed clutch with kroil and let it sit overnight. The next morning it was free, though sometimes you might need to put the tractor against a tree and start it.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2007 Ingersoll...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
