jd 955 mmm problem
/ jd 955 mmm problem #1
billake
I raised the mower and turned the depth control fully clockwise to lock it in the raised position. That worked OK but now i can't get it back down. Any ideas out there?
thanks.
Bill
/ jd 955 mmm problem #2
Bill,
Is the problem that you can't turn the depth control knob? If so raise the deck to take pressure off the depth control. The deck will settle against the depth control adjustment screw making it difficult to turn the knob.
Jeff
Thanks Jeff, Yes, not being able to turn the the depth control is the problem. Sounds like you hit it right on the head. I'll give it a try this week end.
Bill
/ jd 955 mmm problem #4
Bill,
This took me quite a few tries to get stright in my head too. In fact, I think I posted almost the same exact question /forums/images/graemlins/grin.gif
Dave
Jeff,
Just a note to let you know that lifting the deck was the solution. Thanks again, I probably would have broken something next.
Bill
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2017 Ford F-250 Reading Service Truck (A61573)
2017 Ford F-250...
iDrive TDS-2010H...
Cat CB24B (A60462)
Cat CB24B (A60462)
