3-Point Hitch JD 955 Hydrolics
/ JD 955 Hydrolics #1
Old Stallion
Fort Mc Coy
JD 955
Just got an old JD 955 4WD and love it. But I have a few questions about it.
When pushing dirt back my blade climbs over the top. Does this unit put downward pressure when I put the blade down or does it rely solely on the weight of the blade?
What is the water valve looking knob that sits on the left side under drivers seat do?
thanks much for your help, Rick
/ JD 955 Hydrolics #2
Welcome.
No down pressure, weight of implement is all that holds it down.
Knob adjust the rate the 3pt drops. So if you had a real light 1 row plow or something you might adjust it to drop faster. If you had a heavy brush cutter you would have to screw it in to keep it from falling so fast when you lower the rockshaft lever to lower the 3pt hitch.
/ JD 955 Hydrolics #3
As dusty3030 stated very few tractors have down pressure on the 3 pt. Belarus is one brand that has down pressure.
/ JD 955 Hydrolics #6
955 isn't that "old".
John Deere 955
John Deere 955 tractor photo
1989 - 1998
Compact Utility tractor
Smaller: John Deere 855
Distributor: John Deere
Manufacturer: Yanmar
Factory: Japan
Original price (USD): $18,000 (1998)
John Deere 955 Engine:
Yanmar 1.4L 3-cyl diesel
Capacity:
Fuel: 6.6 gal [25.0 L]
Hydraulic system: 4.5 gal [17.0 L]
Front axle: 2.6 qts [2.5 L]
3-Point Hitch:
Rear Type: I
Rear lift (at 24"/610mm): 957 lbs [434 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@3200
Mid PTO: independent
Mid RPM: 2100
Engine RPM: 2100@3200
Dimensions & Tires:
Wheelbase: 64 inches [162 cm]
Weight: 1,990 lbs [902 kg]
Front tire: 7.00-12
Rear tire: 11.2-16
John Deere 955 attachments:
mowing deck
front-end loader
backhoe
955 Serial Numbers:
1990: 10001
1991: 100001
1992: 100700
1993: 130000
1994: 165001
1995: 175130
1996: 190001
1997: 200001
1998: 300001
John Deere 955 Power:
Engine: 33 hp [24.6 kW]
Drawbar (claimed): 23 hp [17.2 kW]
PTO (claimed): 27 hp [20.1 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: standard
Steering: hydrostatic power
Brakes: differential hydraulic wet disc
Cab: Two-post Roll-Gard ROPS. Optional canopy and high ROPS with extra headroom. Optional weather enclosure.
Hydraulics:
Type: open center
Capacity: 4.5 gal [17.0 L]
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 2
Total flow: 7.2 gpm [27.3 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Battery:
Number: 1
Cold-cranking amps: 472
Volts: 12
Woodland Mills Sawmill (A65579)
Woodland Mills...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2005 International 4300 Rollback (A62613)
2005 International...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
