JD 955 Help with leak/seal replacement
   / JD 955 Help with leak/seal replacement #1
BB76
JD 955
Hi guys,
I need some help fixing a leak. Looks like it's coming from the seal on the side of the transmission where the swashplate shaft (M71828) is connected to the v shaped cam for the forward/reverse. I think I need to replace the seal (#22) but it could be the 0-ring (#19) which is part of the trunnion. Has anyone replaced these seals before, and is it doable without dropping the transmission out of the tractor. That darn little seal #22 is like $50 from JD, I can't believe it's so expensive.
Thanks for your guidance!
   / JD 955 Help with leak/seal replacement #2
:welcome: to TBN
Are you working with the service tech manual? or is the pic from jdparts?
JD Parts
   / JD 955 Help with leak/seal replacement #4
BB76, check your messages
2022 Ligchine Spiderscreed Concrete Screed (A55851)
2022 Ligchine...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2014 John Deere 4940 Sprayer (A53485)
2014 John Deere...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2013 JLG SkyTrak 6042 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2013 JLG SkyTrak...
