JD 855 will not shift out of 4WD
   / JD 855 will not shift out of 4WD #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
The title says it all.
Tried shifting while in neutral as well as when tractor moving slowly in forward or reverse.
   / JD 855 will not shift out of 4WD #2
Raise the front end using the FEL, and then try.
   / JD 855 will not shift out of 4WD #3
if this doesn't get it out of the bind it's in, back up 15-20 feet and try it again. Sometimes as the front tires get worn, they end up not traveling the same speed
as the back, when on soft ground it will usually work itself out but on hard ground or asphalt, or spinning tires, sometimes it just needs to "unwind"
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
