Mowing JD 855 Mid PTO drive problem
/ JD 855 Mid PTO drive problem #1
Garth50
Brisbane, QLD, AUS
JD 855
Hi. I have a JD855 with the 72 inch mower deck. It has worked perfectly for years, but recently started losing PTO drive while mowing. It is not the drive disconnecting as the magnet is still engaged. When it happens I can hear the load come off the motor and the deck sounds like it is free wheeling, until it eventually stops. The brake does not come on until I disengage the PTO drive. Disengage and engage the PTO drive and it will work until the next drop out. I think it is load dependent although if I leave it running with no load it will free wheel after a minute or so. I suspect a problem with the PTO clutch piston or clutch because the PTO brake and Delay Relief valve are working normally - implying no problems with hydraulic pressure, correct? Any thoughts before I start pulling the back end apart? Thanks in advance, it is mid summer here and the grass is growing fast.
/ JD 855 Mid PTO drive problem #2
:welcome: to TBN
Do you have the service tech manual for some assistance?
2023 CATERPILLAR 920 WHEEL LOADER (A65056)
2023 CATERPILLAR...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
CATERPILLAR 312D EXCAVATOR (A65056)
CATERPILLAR 312D...
