JD 855 Hydraulic problem
/ JD 855 Hydraulic problem #1
srhorsefarm
Eastern Pa
JD 855
I have a Jd 855 that has a real bad habit of squealing under the seat when the cylinders on my loader are fully stroked in or out and I also lost a lot of
lifting ability with the 3PT. I just purchased a service manual but would like to get as much input as possible to avoid any unnecessary labor. Any info
would be greatly appreciated. (PS I had a most of hydraulic system apart
under the seat looking for something obvious including the rock shaft thought the screen might be clogged.
Thanks, Mike
/ JD 855 Hydraulic problem #2
I would guess that the pressure relief valve is opening too easily. You should take it out (probably a couple washers, a spring and a rounded cup) and see if there is a chunk of gunk keeping it from closing all the way.
I assume that you have already changed the filter in teh system and cleaned any screens, checked fluid levels and have no water in the fluid.
jb
/ JD 855 Hydraulic problem #3
Definitely sounds like a relief valve problem-I suggest you get a gauge and take a measurement of the system pressure. You can get a gauge at TSC or online for under $20.
2022 EZ-GO ELITE...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
6' Howse Bush Hog (A62613)
6' Howse Bush Hog...
Ford F-450 (A63689)
Ford F-450 (A63689)
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
