JD 855 help.
/ JD 855 help. #11
Havoctec said:
A safety switch may be the problem. Not sure about the 855 but it may need to be in neutral, parking brake engaged, pto off, person sitting on seat to depress the switch under it, clutch pushed in.....
Is everything on the tractor the same each time you try to start it?
I used to use a JD 855 at a small horse farm growing up. It's a great little machine the one I worked on has been used and abused in ways most of us would never think to treat a tractor. Almost zero maintaince, roled, swamped, and worked hard every single day and just keeps running after 15+ years.
In any event, the one I drove would crank when the preheat light was still on, there was not a lock out switch. In the winter (-20 to 30 degree's) it could take what felt like a full minute for the light to go out. When it was real cold sometimes you'd need to cycle the pre heater 2 or 3 times before it would finally start.
Also, we did have a problem once with it not starting "sometimes" the starter, battery etc were all good. Turned out to be the safty switch under the seat, There is a rod that must be depressed before the hydro would engage (I don't know if your's is a hydro). Somehow that rod was bent to the point that the seat would not fully engage the safty switch. I don't know if it will help you but it might be worth looking under the seat to see if the seat and switch are making contact.
/ JD 855 help.
....Uh....no!
....my friend just kinda turns it off and leaves it in whatever state it was when it was shut off....
Does it need to be in neutral, PTO off, park brake on, there is no clutch.
I know about the seat switch but that's it.
Let me know so I can relay this to my "friend".
Because he's an Idiot!
Thanks,
/ JD 855 help. #14
855Idiot said:
....Uh....no!
Thanks,
Tell your friend to try all of that and let you know if it takes care of the "no start sometimes" problem.;) .. My JD 770 will not crank unless I put it in neutral, turn PTO off, doesn't matter if park brake is on or off, mine has a clutch and I press it anyway but don't think it matters , butt is on the seat.
good luck....
/ JD 855 help. #15
The 55 series are all Hydrostatic - 655,755,855,955.
The preheat light will have no effect on starter engagement. The light shouldn't be on all the time. If your air heater is on all the time it will probably burn up. There is an electric plug-in module mounted on the firewall that controls the air heater. I had dirt in the plug prongs which gave me problems. I removed the module, cleaned the prongs and recepticle and now all is well.
The seat switch or PTO being engaged will also stop cranking, as others have said.
/ JD 855 help.
With all your help, my friend and I, (and I wish he knew more about tractors)
put the starter back on,
tested the seat switch and found it working,
disengaged the PTO,
put in neutral--hard to find as the lever is not accurate.
put the park brake on.
No crank?
I'm suspecting the key, PTO, or neutral switch or the wires in between them.
It's possible I may not be finding the real neutral position with the lever.
After last night, here is what "we" learned.
When the key is turned to on, the battery, oil and temp light are on, NOT the preheat-sorry I mislead you.
Turning the key will yield a single "click" from the control module (part number AM102118), located just behind the key switch.
I'm going to begin tracing/testing wires next--as my friend has been no help:rolleyes:
Any suggestions, comments, insults would be welcome
Thanks,
Glenn
/ JD 855 help. #17
Have you tested the battery? That is the first thing I would check. Forgive my ignorance on tractors, but is there a starter solenoid? The only other thing I could think of would be somehow the tractor thinks the PTO is engaged. I'm not sure where that connector is, but perhaps you could check that. Sorry I don't have any answers, I'm just talking outloud about how I would debug the situation.
/ JD 855 help. #18
disengaged the PTO,
No crank?
Thanks,
Glenn
I posted this as part of a PM I replied to you. After reading your last post I thought I should clarify.
"As for other things to check, the tractor won't start if the HST peddles are not in "Neutral" next time it won't start try to play with the HST peddles, it maybe that the spring needs to be adjusted. The PTO also has a safety switch but I would doubt that龍 your problem."
With the 855 I worked on putting the Hi-lo "gear shift" lever into neutral will not help. what will cause the problem you are describing is the HST peddles not "centering." For example if you were to fully depress the foward peddle the tractor would not start. On the one I used to drive sometimes one would have to depress and release the peddles a few time to "help" it get back to center. This should be easy for you and "your friend" to test.
/ JD 855 help.
I'll mess with the pedals today along with the neutral lever.
Pedals seem stiff and not much play when it's not running.
The battery is less than a week old.
When it cranks, it roars to life instantly.
I'm going to check and see if find a manual today.
It has to be something simple/stupid that "we" can't figure out.
Something is telling it not to start.
Thanks,
Glenn
/ JD 855 help. #20
I would suspect the neutral switch on the hydro pedal linkage. It is probably going bad or not adjusted properly. It is not very easy to get to. If the tractor sits still when running, then adjustments to linkage are probably ok. If the tractor "creeps" then adjustment or lubrication of stiff linkage may help. The switch is located under the tin cover between your legs near where your right heel rests on platform, although you really need to access it from under the tractor. There is also a neutral switch in pto circuit that could be bad or have a loose connection.
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
2020 DRAGON ESP...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2025 BrushFox XHD-78HF 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A59228)
2025 BrushFox...
