JD 855 help.
/ JD 855 help. #21
I think we are on the right track here. I agree its probably the hydro pedal ("neutral interlock"), PTO interlock, or related wiring. I used to have a similar 755 with the same problem. It happened once in a while, but I never took the time to fully diagnose it before I sold it. I think all of the interlocks tie into enabling the fuel shutoff solenoid on the fuel injection pump. It has the rubber boot on it and you should see it engage when you turn the key to start. I think this it turn, enables the starter solenoid. I used to have a repair manual for my tractor and recommend you look for one on Ebay or from the dealer. They are expensive ($100+) but a must have for an older, pre-enjoyed tractor. They have full electrical schematics which along with a test light and/or multi-meter should help you find the loose/dirty connection.
Good luck.
/ JD 855 help.
I "we" got into it this afternoon. Ripped everything off and followed the Purple wire from the key switch to the pedal switch and everywhere else.
Cleaned & tested every connector + switch along the way.
Tried the key and Magic!
Fired right up!
Several times in a row!
Still intermittently not starting though? I've got to be on the right track.
Amazing amounts of dust and dirt came out of each connector/switch.
All of the sensors were corroded and needed polishing/cleaning.
Things are looking up:D
/ JD 855 help. #23
I have a 955 with an electrical problem. I have changed the battery, new key switch, new fuses but when I turn on the key switch, I do not get any lights to come on on the dash. I have traced the power and I have power 12V to the switch. Any help would be great.
/ JD 855 help. #24
I had the same problem on my 855. I replaced the battery and the starter solenoid. That fixed the problem.
/ JD 855 help. #25
If you are still looking for a manual, try this <http://www.selectmanuals.com/advanced_search_result.php?search_in_description=1&keywords=4410>
/ JD 855 help. #26
Where are you referencing ground from? Double check battery negative cable at the chassis side, take it off and clean the connection.
2017 Ford F-250 Reading Service Truck (A61573)
2017 Ford F-250...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2022 EZ-GO ELITE...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
2014 F-150 STX (A56438)
2014 F-150 STX...
