jd 850 PTO question
/ jd 850 PTO question #1
lilburr
carolina on the banks of the savannah
fordson, john deere
I guess the main question would be 'where is the PTO shifter located' on a 1980 JD 850 2WD ?
hello, newbie here and I am looking at a 1980 JD 850. Cranked it and drove it a little yesterday and I am impressed with this little tractor. Only problem was that I could not dis-engage the PTO - it spun all test drive except when clutch was depressed. I may have been shifting the wrong lever - I was shifting a lever on the right side of 'hump', a flat kinda shifter that had a high, low, and neutral setting and shifted quite easily but did not dis-engage PTO. A shifter under the left side of seat - longish that had a knob on the end seemed almost non-functional smooth from floor to under seat.
/ jd 850 PTO question #2
PTO shifter is to your left by the fender while seated on the machine. You may have a black or yellow handle depending on which year you have. You need to put the clutch in to shift in or out of gear. There were two different series I think below 16000 serial number is a single stage clutch after (around 1984) is a two stage clutch which will let you stop forward motion but still have the pto in gear until you press the clutch all the way down.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2005 Kobelco 135SR Hydraulic Excavator (A59228)
2005 Kobelco 135SR...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
