JD 850 and bush hog
   / JD 850 and bush hog #1
redka
Middle GA
Can a JD 850 run a 6 ft. bush hog? Thanks
   / JD 850 and bush hog #2
Yes, but may just have to go slower in tall, thick stuff. Also may have to have some additional counter weight on the front end if lifting with 3 ph.
   / JD 850 and bush hog #3
I wouldn't.
I owned an 850, and if I remember right it was only 25/26 HP (22 PTO HP)
Mine would struggle in thick, deep grass with a 5' cutter. It handled a 6' belly mower fine.
   / JD 850 and bush hog #5
If it doesn’t have a loader you’ll probably want some suitcase weights on the front with either a 5’ or 6’ although the light front end does make it steer easy if it doesn’t have power steering.
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
(2) 48" HANG ON...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
