JD 850 and bush hog
   / JD 850 and bush hog #1
redka
Middle GA
Can a JD 850 run a 6 ft. bush hog? Thanks
   / JD 850 and bush hog #2
Yes, but may just have to go slower in tall, thick stuff. Also may have to have some additional counter weight on the front end if lifting with 3 ph.
   / JD 850 and bush hog #3
I wouldn't.
I owned an 850, and if I remember right it was only 25/26 HP (22 PTO HP)
Mine would struggle in thick, deep grass with a 5' cutter. It handled a 6' belly mower fine.
   / JD 850 and bush hog #5
If it doesn’t have a loader you’ll probably want some suitcase weights on the front with either a 5’ or 6’ although the light front end does make it steer easy if it doesn’t have power steering.
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55315)
Michelin CARGOXBIB...
2013 International Derrick Digger Truck (A55973)
2013 International...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2019 Deere 35G (A53317)
2019 Deere 35G...
